Motor driver
Voltages
Wheel motors wiring
- steer the robot left/right
Wheel motor features:
- A high torque (2.45Nm) guarantees that the robot can climb small hills as well (with 2 motors, 0.125 radius wheel, 31rpm = 0.4m/s, acceleration = 0.2 ( 1/2 of nomeinal speed) see calculator
- 24V (load current ~1A)
Motor decrease noise
Protector PCB
Protector board is adviced to be used between controller and motor
Motor wiring (left motor):
Odometry wiring
Mower motor wiring
Motor wiring (mower motor):
Motor controller (PID)
