Motor driver
Voltages
Wheel motors wiring
- steer the robot left/right
Wheel motor features:
- A high torque (2.45Nm) guarantees that the robot can climb small hills as well (with 2 motors, 0.125 radius wheel, 31rpm = 0.4m/s, acceleration = 0.2 ( 1/2 of nomeinal speed) see calculator
- 24V (load current ~1A)
Motor decrease noise
Protector PCB
When quickly tunring motors from forward to backward (or vice versa), high voltage spikes appear. These high voltage spikes could damage the motor driver in the long run. To eliminate these high voltage spikes, it is adviced to use a Protector board between motor driver and motor.
Motor wiring (left motor):
Odometry wiring
Mower motor wiring
Motor wiring (mower motor):
Motor controller (PID)
