Motor driver
Voltages
Wheel motors wiring
- steer the robot left/right
Wheel motor features:
- 24V (load current ~1A)
Motor decrease noise
Protector PCB
When quickly tunring motors from forward to backward (or vice versa), high voltage spikes appear. These high voltage spikes could damage the motor driver in the long run. To eliminate high voltage spikes, it is adviced to use a Protector board between motor driver and motor.
Motor wiring (left motor):
Odometry wiring
The Ardumower motors have integrated encoders. These encoders help us to compute speed and traveled distance. Here's how you connect the motor odometry wires to the PCB.
Mower motor wiring
Motor wiring (mower motor):
Motor controller (PID)
