Motor driver
Version vom 1. Juni 2016, 05:09 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Motor driver assembly (dual MC33926))
Voltages
Wheel motors wiring
  • steer the robot left/right
Wheel motor features:
  • 24V (load current ~1A)
Motor decrease noise
Protector PCB
Warning.png When quickly tunring motors from forward to backward (or vice versa), high voltage spikes appear. These high voltage spikes could damage the motor driver in the long run. To eliminate high voltage spikes, it is adviced to use a Protector board between motor driver and motor.
The left gear motor is connected as follows to the motor driver (MC33926):
Motor wiring (left motor):
Motor (black)  ==== MC33926 M1OUT1
Motor (red)    ==== MC33926 M1OUT2
Odometry wiring
The Ardumower motors have integrated encoders. These encoders help us to compute speed and traveled distance. Here's how you connect the motor odometry wires to the PCB.
Motor (brown)  ---- PCB VCC
Motor (green)  ---- PCB GND
Mower motor wiring
Here's how you connect the mowing motor to the motor driver (MC33926):
Motor controller (PID)
