Motor driver
Version vom 1. Juni 2016, 05:25 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Motor driver assembly (dual MC33926))
Voltages
Wheel motors wiring
  • steer the robot left/right
Wheel motor features:
  • 24V (load current ~1A)
Motor decrease noise
Protector PCB
Motor wiring (left motor):
Odometry wiring
The Ardumower motors have integrated encoders. These encoders help us to compute speed and traveled distance. Here's how you connect the motor odometry wires to the PCB.
Motor (brown)  ---- PCB VCC
Motor (green)  ---- PCB GND
Mower motor wiring
Here's how you connect the mowing motor to the motor driver (MC33926):
Motor (black)  ==== MC33926 M1OUT1
Motor (red)    ==== MC33926 M1OUT2
Motor controller (PID)
