Motor driver
Version vom 2. Juni 2016, 21:12 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Motor driver assembly (dual MC33926))
Voltages
For motor driver, protector and motor wiring, please open manual in section Protector PCB.
Protector PCB
Wheel motors wiring
  • steer the robot left/right
Wheel motor features:
  • 24V (load current ~1A)
Motor wiring (left motor):
Wheel motors odometry wiring
Motor (brown)  ---- PCB VCC
Motor (green)  ---- PCB GND
Mower motor wiring
Motor decrease noise
Motor controller (PID)
