Motor driver
[Image:Ardumower_motordriver_overview.png Overview: PCB, motor drivers, protector, motors]
Voltages
Protector PCB
Wheel motors wiring
- steer the robot left/right
Wheel motor features:
- 24V (load current ~1A)
Motor wiring (left motor):
Wheel motors odometry wiring
Mower motor wiring
Motor decrease noise
Motor controller (PID)
