Ardumower Chassis 'mountain mod'
Version vom 20. August 2016, 14:39 Uhr von Alexanderg (Diskussion | Beiträge)
This page describes how to modify the Ardumower Chassis to run up higher slopes with it (tested up to 30 percent). This works by
- modifying the tire profile (give it more grip)
- Modify tire profile OR
- Off-road version (sand etc.): A bicycle tube is added around the tire
Needed parts
- cup
- acrylic glas sheet
- rubber band
- swap motor cables (right and left)
- swap odometry cables (right and left)
- swap battery charging pin cables (right and left)
- disable ultrasonic sensor
- move perimeter coil from old front to old back side
Pictures
- Demo
- Optimized tires
