Version vom 7. Januar 2017, 19:06 Uhr von Alexanderg (Diskussion | Beiträge) (→Rotate and move until sensor trigger)
Message format
Not defined yet (ideas: NMEA 0183, SAE J1939, ...)
Messages
System control
- Get implemented message types:
- application control
- actor and sensor control
- propriertary
Application control
- $RMMOW: Set mowing state (start mowing, stop mowing, go to docking station)
- $RMSTA: Robot state event (robot state, errors, battery)
- $RMSEN: Robot sensor event (sensor values, sensor trigger counters)
- $RMCFG: Robot mower configuration (available sensors)
$RMMOW,s<cr><lf>
$RMSTA,s,e,b,h,d<cr><lf>
- s: stopped (0), mowing (1), busy (2)
- e: error
- b: battery percent
- d: moved distance in meter since last event
- bl: bumperLeft
- br: bumperRight
- bc: bumperCenter
- pfl: perimeterFrontLeft
- pfr: perimeterFrontRight
- pfc: perimeterFrontCenter
- prl: perimeterRearLeft
- prr: perimeterRearRight
- prc: perimeterRearCenter
- ih: IMUcompassHeading
- ip: IMUpitch
- pr: IMUroll
- ga: GPSlatitude
- go: GPSlongitude
Robot mower configuration (type of sensors)
- o: Odometry available (1/0)
- g: GPS available (1/0)
Actor and sensor control
- $RMMOV: Rotate by x degrees and move with speed y RPM until sensor trigger
- $RMMOV: Keep ongoing action (mower communications saftety)
$RMMOV,d,r<cr><lf>
- d: rotate degrees
- r: move rpm
Keep ongoing action
$RMCOA<cr><lf>
Proprietary
- Any proprietary messages not defined by this protocol
