Version vom 8. Januar 2017, 06:59 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Robot state event (robot state, errors, battery, charger))
Message format
message structure: $IDMSG,data,<cr><lf>
message components:
  • $: start of message symbol
  • data: comma separated message data (see below) - if a value is not existing it can be empty
example: $RMSEN,1,1,,,,0,1,,0,179.8,,,0,0<cr><lf>
Messages
  • $RMMOW: Set mowing state (start mowing, stop mowing, go to docking station)
  • $RMSEN: Robot sensor data event (sensor values)
  • $RMCFG: Robot mower configuration (available sensors)
  • $RMMOV: Move robot until sensor trigger
  • $RMKOA: Keep ongoing action (mower communications saftety)
  • $DWDAT: beacons ranging data (e.g. DW1000)
$RMMOW,s<cr><lf>
  • ts: timestamp ms
  • e: error code
  • b: battery percent
  • bl: battery low (0/1)
  • c: charging percent
  • l: left odometry counter
  • r: right odometry counter
$RMSEN,ts,bl,br,bc,pfl,pfr,pfc,prl,prr,prc,ih,ip,ir,ga,go,ul,ur,uc<cr><lf>
  • ts: timestamp ms
  • bl: bumperLeft
  • br: bumperRight
  • bc: bumperCenter
  • pfl: perimeterFrontLeft
  • pfr: perimeterFrontRight
  • pfc: perimeterFrontCenter
  • prl: perimeterRearLeft
  • prr: perimeterRearRight
  • prc: perimeterRearCenter
  • ip: IMUpitch degree
  • pr: IMUroll degree
  • ga: GPSlatitude
  • go: GPSlongitude
  • ul: ultrasonicLeft
  • ur: ultrasonicRight
  • uc: ultrasonicCenter
  • ts: timestamp ms
  • ml: motorLeftStall
  • mr: motorRightStall
  • bl: bumperLeft
  • br: bumperRight
  • bc: bumperCenter
  • t: robot orientation tilt
Robot mower configuration event (protocol version, type of sensors)
$RMCFG,p,m,d,pfl,pfr,pfc,prl,prr,prc,ih,ip,o,g,ul,ur,uc<cr><lf>
  • p: robot is using protocol version (1)
  • m: robot requires minimum protocol version (1)
  • o: Odometry available (1/0)
  • g: GPS available (1/0)
Move robot until sensor trigger command
$RMMOV,l,r,p,i,d,o<cr><lf>
  • l: left motor target ticks per frame
  • r: right motor target ticks per frame
  • p: PID_Kp
  • i: PID_Ki
  • d: PID_Kd
  • o: PID_Ko
Keep ongoing action command (mower communications saftety)
$RMKOA<cr><lf>
  • mower will stop moving if not receiving another message within 2 seconds
Beacons ranging data event (e.g. DW1000)
  • t: timestamp ms
Proprietary
