Version vom 8. Januar 2017, 18:04 Uhr von Alexanderg (Diskussion | Beiträge) (→‎ultrasonic sensor event)
Message format
message components:
  • $: start of message symbol
Messages
  • $RMBUM: bumper sensor event
  • $RMODO: odometry event
  • $RMGPS: GPS event
  • $RMIMU: IMU event
$RMMOW,s<cr><lf>
  • ts: timestamp ms
  • e: error code
  • b: battery percent
  • bl: battery low (0/1)
  • c: charging percent
  • l: left odometry counter
  • r: right odometry counter
  • ts: timestamp ms
  • ml: motorLeftStall
  • mr: motorRightStall
  • bl: bumperLeft
  • br: bumperRight
  • bc: bumperCenter
  • pfl: perimeterFrontLeft
  • pfr: perimeterFrontRight
  • pfc: perimeterFrontCenter
  • prl: perimeterRearLeft
  • prr: perimeterRearRight
  • prc: perimeterRearCenter
  • t: robot orientation tilt
  • ul: ultrasonicLeft
  • ur: ultrasonicRight
  • uc: ultrasonicCenter
Robot mower configuration event (protocol version, type of sensors)
  • i: messages implemented bitmask ($RMMOW, $RMSTA, $RMSEN, $RMTRG, $RMCFG, $RMMOV, $RMKOA, $RMBEA) - example: 10001000
  • o: Odometry available (1/0)
  • g: GPS available (1/0)
$RMMOV,m,l,r,p,i,d<cr><lf>
  • l: left motor target rpm
  • r: right motor target rpm
  • p: PID_Kp
  • i: PID_Ki
  • d: PID_Kd
$RMKOA<cr><lf>
$RMSON: ts, bl, br, bc,
  • ts: timestamp ms
bumper sensor event
$RMBUM: ts, bl, br, bc
  • ts: timestamp ms
  • bl: bumperLeft
  • br: bumperRight
  • bc: bumperCenter
odometry event
$RMODO: ts, ol, or
  • ts: timestamp ms
  • ol: left odometry
  • or: right odometry
GPS event
$RMGPS: ts, ga, go
  • ts: timestamp ms
  • ga: GPSlatitude
  • go: GPSlongitude
$RMPER: ts, pfl, pfr, pfc, prl, prr, prc
  • ts: timestamp ms
IMU event
$RMIMU: ts, ih, ip, ir
  • ip: IMUpitch degree
  • ir: IMUroll degree
  • t: timestamp ms
Proprietary
