Version vom 28. April 2017, 14:32 Uhr von Gimate (Diskussion | Beiträge) (→‎Simulation: Link korrigiert)
NOTE: Everything under development here. Just showing ideas! :-)
  • speed (m/s)
  • direction (degree)
  • position (x,y - meter)
Sensor errors
  • Odometry: accumulation error (e.g. 15cm per meter), update rate: 10-20 Hz
  • Gyro: accumulation error (e.g. 0.03 degree per second), update rate: 10-20 Hz
  • Compass: noise (e.g. 1 degree), update rate: 10-20 Hz
  • GPS: noise (e.g. 2m), update rate: 1-5 Hz
Odometry sensor error
  • Distance: 20cm per meter
  • Course: 10 degree per meter
Sensor fusion (EKF)
Gyro         => Rotation speed delPhi   =>
Course(GPS)  => Course phiGPS           => Kalman =>  Course phi       =>
Odometry     =>                                       Distance Sl, Sr  =>  Kalman  =>  Position x,y, Course phi
Sensor fusion (Gyrodometry)
The idea of 'Gyrodometry' is to compare delta phi of gyro and odometry. If it is higher than a certain threshold, use gyro delta phi, otherwise odometry delta phi.
if (deltaPhiGyro - deltaPhiOdo) > deltaThres
  phi = phi + deltaPhiGyro * T
else
  phi = phi + deltaPhiOdo * T
Position recalibration at perimeter border
  1. Learn mode: robot completely tracks perimeter wire once and saves course (degree) and distance (odometry ticks) in a list (perimeter tracking map).
  2. Position detection: robot starts tracking the perimeter wire at arbitrary position until a high correlation with a subtrack of the perimeter tracking map is found. There it can stop tracking and knows its position on its perimeter tracking map.
Mapping and localization (SLAM)
Input to SLAM algorithm:
  • control values (speed, steering)
  • observation values (speed, heading, magnetic field strength)
Output from SLAM algorithm:
  • magnetic field map (including perimeter border)
  • robot position on that map (x,y,theta)
Example SLAM algorithms:
  • Particle filter-based SLAM plus Rao-Blackwellization: model the robot’s path by sampling and compute the 'landmarks' given the poses
SLAM simulation
  1. The simulator code can be found in SVN
  2. The simulator IDE+compiler+precompiled libs (CodeBlocks) can be downloaded here - Extract the .zip to 'C:\codeblocks' and run 'sim.cbp'
Videos: Magnetic field localization using particle filter
Lane-by-lane mowing
Assuming a lane length of 10m, and a lane width error of +/- 0.1m, the maximum allowed yaw error is:
yaw error=arcsin(0.1m/10m) = 0.5 degree
Assuming that robot moves at 0.4m/sec, the actual yaw error can be computed like this:
 actual time needed = 10 meters / 0.4m/sec = 25 seconds
Actual yaw error (assuming gyro noise 0.005 degree/sec):
actual yaw error = 0.005 degree/sec * 25 seconds = 0.125 degree
Sensor logging
Simulation
