Ardumower Sunray
Version vom 29. April 2017, 15:23 Uhr von Alexanderg (Diskussion | Beiträge) (→User interface (for testing/development))
- PCB 1.3 (incl. MC33926 motor drivers)
- Arduino Due
- IMU GY-88 (MPU6050, HMC5883L)
- 2 perimeter coils (left, right), perimeter sender
- motors using odometry
- Bluetooth module
Code
Compass calibration
- Move IMU out of robot and power-on robot.
- Rotate IMU module slowly into all directions and collect > 20,000 measurements. Calibration ist performed transmitted continously to robot (robot confirms with a tone).
- On the PC, start 'processing_sunray'. The robot's sensors should be shown. At start (and every 3 minutes), the robot calibrates the Gyro and calibration status is shown in the user interface. After this is completed, you can verify the compass calibration by rotating the robot using the green joystick shown on the screen. Compass yaw and gyro yaw should be the same up to 3 degree.
Important settings
String comPort = "COM9"; String logFile = "outdoor_mow_rand.log"; // if file exists, playback mode, otherwise record mode
Mapping
Localization
You can reset the particle filter by clicking 'reset particles'. In tracking mode slightly different particle filter parameters will be used than during ordinary mowing. You can set the robot's position manually (kidnap robot) by clicking on the map.
Random mowing
Lane-by-lane mowing
Perimeter tracking
- On the PC, choose 'track'
