Ardumower Sunray
Ardumower Sunray is the next Firmware (experimental) for the Ardumower. It uses odometry, an IMU (gyro+compass) and a perimeter to localize itself on the perimeter and within the perimeter. A particle filter estimates the robot position on a map based on moved distance and absolute angle.
- Arduino Due
- Bluetooth module and PC using USB Bluetooth dongle (e.g. Delock EDR 150m)
PCB1.2
Arduino Due operates at 3.3v - PCB1.2 is not designed to work for 3.3v, however you can modify and use PCB1.2 (with limitations/on your own risk):
- HC-05 module operates at 5v
Code
- Using Arduino IDE, flash the Sunray firmware onto your Arduino Due: https://github.com/Ardumower/Sunray
- Using 'processing_sunray', verify that the bluetooth connection to the Firmware is working.
Bluetooth connection
String comPort = "COM9";
Compass calibration
- On the PC, start 'processing_sunray'. The robot's sensors should be shown. At start (and every 3 minutes), the robot calibrates the Gyro and calibration status is shown in the user interface. After this is completed, you can verify the compass calibration by rotating the robot using the green joystick shown on the screen. Compass yaw and gyro yaw should be the same up to 3 degree.
Recording / Playback
Mapping
Localization
A particle filter will estimate the robot's position on the map. You can reset the particle filter at any time by clicking 'reset particles'. In tracking mode, slightly different particle filter parameters will be used than during ordinary mowing. You can set the robot's position manually (kidnap robot) by clicking on the map.
Random mowing
Lane-by-lane mowing
Perimeter tracking
- On the PC, choose 'track'
