Ardumower Sunray
- 3 Requirements
- 4 Code
- 5 IMU calibration
- 6 Compass calibration
- 7 User interface (for testing/development)
- 8 Error/pitfalls
- 9 Discussion / forum thread
- Optimized for Arduino Due (no longer sensor polling, individual pin interrupt handling, DMA transfers, flexible ADC sampling frequencies...)
- Optimized for slope and odometry (no longer imprecise time-based driving distances or rotations)
- Optimized for MPU6050 and DMP (digital motion processor)
- Arduino Due
- IMU GY-88 (MPU6050, HMC5883L), installed on a 'tower', NOTE: you have to connect pin AD0 to 3V3 so the I2C address does not conflict with the RTC module
Code
- Using Arduino IDE, flash the Sunray firmware onto your Arduino Due: https://github.com/Ardumower/Sunray (you may have to adjust serial ports in config.h).
- Install Processing (https://processing.org/download/).
- Using Processing, run 'processing_sunray' and verify that the bluetooth connection to the Firmware is working.
Bluetooth connection
String serialport = "COM14";
IMU calibration
NOTE: It's recommended to skip this part until you have done the basic tests in 'processing_sunray' (see further below). Put or hold IMU in a straight position without pitch and roll. Run 'processing_sunray', and click on 'MPU selftest'. The displayed robot pitch and roll should now match the real robot pitch and roll.
Compass calibration
NOTE: It's recommended to skip this part until you have done the basic tests in 'processing_sunray' (see further below). Ardumower Sunray relies on a carefully-performed compass calibration, so it knows the robot's direction up to 3 degrees.
- On the PC, start 'processing_sunray'. The robot's sensors should be shown. At start (and every 3 minutes), the robot calibrates the Gyro and the IMU calibration status is shown in the user interface (the robot will make short buzzer beeps during gyro calibration time). After this is completed, you can verify the compass calibration by rotating the robot using the green joystick shown on the screen. Compass yaw and gyro yaw should be always the same (up to 3 degrees).
Test functions
- line : robot should move on a straight line
- line rev : robot should move reverse on a straight line
- rotate +90deg : robot should rotate counter-clockwise 90 degree
Recording / Playback
- outdoor_track.log (robot tracking a 120m perimeter)
- outdoor_mow_rand.log (robot randomly mowing inside a 120m perimeter with annotated ground truth)
Mapping
Localization
Random mowing
Lane-by-lane mowing
Perimeter tracking
- On the PC, choose 'track'
Particle filter tuning
Stuck detection
Error/pitfalls
frq counter: if 'frq' counter is decreasing significantly, check I2C cables
