Ardumower Gasoline
Ardumower Gasoline R/C is an ordinary gasoline powered mower converted to remote control (R/C) using Ardumower parts.
Parts list
All parts can be purchased in the shop
. Click on a part for more details:
- 2x 260mm tires
- this 3d printed tire adapter or this one
- 1x free wheel
- 2x clamping elements
- 2x Ardumower gear motors
- 2x motor drivers BTS7960
- 1x Ardumower Power pack charger
- 1x Ardumower Power pack battery
- 1x DC/DC converter
- 1x Arduino Nano
- Arduino Nano I/O shield
- a model R/C receiver and a remote control
- 1x fuse holder
- 1x fuse 4A
- 1x diode 10A
- 1x emergency switch
- 1x charging socket
Motors
Free wheel
Control box
Wiring
Connect the components as shown below. The emergency switch is to switch on and off the battery. The fuse holder will hold the 4A fuse. The diode is used to get down the battery voltage by at least 0.5 volt so the overvoltage protection of the BTS7960 motor drivers to not take place when the battery is fully charged. The DC/DC converter converts the Ardumower Power Pack battery 24v down to 9v for the Arduino voltage input. The motor drivers control the two motors via the Arduino Nano. The signal of two model R/C receiver channels are sent to the Arduino Nano allowing the user to steer the mower and to control the speed. The charging socket is used to connect the Ardumower charger for charging the battery.
left BTS7960 Arduino pin GND GND VCC +5V R_EN A1 L_EN A0 R_PWM 9 L_PWM 10
right BTS7960 Arduino pin GND GND VCC +5V R_EN A3 L_EN A2 R_PWM 3 L_PWM 11
model R/C channel Arduino pin GND GND VCC +5V CH_Steering 5 CH_Speed 6
Arduino code upload
Finally, upload this code to your Arduino Nano:
https://github.com/Ardumower/ardumower/blob/master/code/tests/rcmower/rcmower.ino
