Ardumower Gasoline
Ardumower Gasoline R/C is an ordinary gasoline powered mower converted to remote control (R/C) using Ardumower parts.
Parts list
All parts can be purchased in the shop
. Click on a part for more details:
- 2x 260mm tires
- this 3d printed tire adapter or this one
- 1x free wheel
- 2x clamping elements
- 2x Ardumower gear motors
- 2x motor drivers BTS7960
- 1x Ardumower Power pack charger
- 1x Ardumower Power pack battery
- 1x DC/DC converter
- 1x Arduino Nano
- Arduino Nano I/O shield
- a model R/C receiver and a remote control (e.g. 2.4 Ghz R/C control)
- 1x fuse holder
- 1x fuse 4A
- 1x diode 10A
- 1x emergency switch
- 1x charging socket
Motors
Free wheel
Control box
Wiring
left BTS7960 Arduino pin GND GND VCC +5V R_EN A1 L_EN A0 R_PWM 9 L_PWM 10
right BTS7960 Arduino pin GND GND VCC +5V R_EN A3 L_EN A2 R_PWM 3 L_PWM 11
model R/C channel Arduino pin GND GND VCC +5V CH_Steering 5 CH_Speed 6
Arduino code upload
- Download and install Arduino IDE
- Upload this code to your Arduino Nano:
https://github.com/Ardumower/ardumower/blob/master/code/tests/rcmower/rcmower.ino
