Raindancer Firmware (English)
Version vom 30. Mai 2018, 12:32 Uhr von Roland (Diskussion | Beiträge) (→‎Check des closed loop control services)
!!! I am currently translating this side. !!!
Github Download
Overview
Example: clc.enc
Example: pc.cm,60,30       //drives 60 cm with speed 30 (//drives... does not belong to the command)
Which modes will start when:
Open points
  • Stability of the software in the long term. Stand 28.04.2018 Currently, the current software version mowed 63h, has traveled 59km and has rotated 8426 times
  • The line tracking algorithm has been recently optimized for the rear wheel drive chassis. Due to the short distance between coil and the wheels of the original Ardumower chassis, it may be necessary to program another algorithm.
  • Optimization for the original Ardumower chassis (Mowing works very well with the workaround, if necessary, play with the parameters CONF_PER_CORRECTION_ANGLE and CONF_PERIMETER_DRIVE_BACK_CM)
  • Dodge objects close to the perimeter (SecondReverse2 in the BHT)
  • Program one-sided accessible charging station
  • Use RTC to program start at a defined time
Other wishes
  • Integrate rain sensor
  • The charging station is currently only counterclockwise approached.
  • Amplify the signal of the charging station to + -20V voltage stroke
  • SRF08 integration
  • Integrate I2C temperature sensors
  • An external start / stop button that starts or stops mowing
  • Approachthe charging station with GPS. Drive 15m before the charging station on the perimeter and then drive into the charging station..
  • GPS map - the mower may not recognize the signal in the middle of the lawn because the signal is too weak. You can then use GPS to see if you are on the lawn area. If you now say that the signal must be detected at least 15m away from the perimeter, you can neglect the signal within the area if the GPS signal indicates that you are on the lawn.
  • GPS Map - Note where mower has already mowed. Then mow in less mowed areas if necessary.
  • PCB1.3 with Arduino DUE
  • BT module
  • 24V power supply
Optional can be used
  • RTC with EEPROM
#define ARDUMOWER_CHASSIS  false
Console Speed:
has to be changed to:
  #define PWM_FREQUENCY 3900
  #define TC_FREQUENCY 3900
Errorhandling
error     //show errormessage
show.hist   //show history
A
Commissioning of the motors
Enter the command:
Commissioning the encoder
Enter the command  clc.mt, 1,150 to make the left wheel turn.
Enter then  clc.enc This will display the encoder values ​​from the left and right wheels.
Example:  Engine 1 = left - should not count if only the right engine is running.  Engine 2 = right - should not count if only the left engine is running.  ! 03, motor 1 enc: 972 absEnc: 972 rpm: 2.596326 m / h: 125.773315 deltaTicks: 2 deltaTime: 32986us  ! 03, motor 2 enc: 974 absEnc: 974 rpm: 3.325853 m / h: 161.113647 deltaTicks: 2 deltaTime: 33445us  ! 03, motor 1 enc: 974 absEnc: 974 rpm: 2.923552 m / h: 141.625061 deltaTicks: 2 deltaTime: 33156us  ! 03, motor 2 enc: 975 absEnc: 975 rpm: 2.678638 m / h: 129.760696 deltaTicks: 1 deltaTime: 33144us  ! 03, motor 1 enc: 976 absEnc: 976 rpm: 3.132316 m / h: 151.738159 deltaTicks: 2 deltaTime: 32857us  ! 03, motor 2 enc: 976 absEnc: 976 rpm: 2.296233 m / h: 111.235962 deltaTicks: 1 deltaTime: 32859us  ! 03, motor 1 enc: 978 absEnc: 978 rpm: 3.251686 m / h: 157.520752 deltaTicks: 2 deltaTime: 32998us The example shows that the encoders are counting up. 'Example motor 1' : enc: 972 then enc: 974, then enc: 976 ... 'Example motor 2' : enc: 972 then enc: 975, then enc: 976 ...
If the enc value counts negative when driving forward you can configure it in the config.h:  #define CONF_LEFT_ENCODER_INVERSE false  #define CONF_RIGHT_ENCODER_INVERSE false To do this, set CONF_LEFT_ENCODER_INVERSE to true for the left wheel. Set CONF_RIGHT_ENCODER_INVERSE to true for the right wheel.
Do the same for the right wheel:  clc.mt, 2,150
Enter:   clc.v, 30 Moving forward with speed 30% then   clc.v, s stop engine then   clc.v, -30 drives reverse with speed 30%
Mähmotor Inbetriebnahme
z          //mow motor start
t          //mow motor stop
Perimeter Inbetriebnahme
Beispiel per.resultl
Achtung, bei per.resultl und per.resultr wird das Vorzeichen der Amplitude wie tatsächlich empfangen angezeigt unabhängig von den Einstellungen in CONF_LEFT_COIL_INVERSE und CONF_RIGHT_COIL_INVERSE. Es kann sein, dass per.resultl eine positive Amplitude liefert und per.resultr eine negative. Das ist OK, da es von dem Anschluss der Spulen abhängt. Die Umrechnung mit CONF_LEFT_COIL_INVERSE/CONF_RIGHT_COIL_INVERSE findet in der Software später statt. Wichtig ist, das CONF_LEFT_COIL_INVERSE und CONF_RIGHT_COIL_INVERSE so konfiguriert werden, dass per.show innerhalb der Spule positive Amplituden anzeigt.
Konfiguration Bluetooth
Einstellen Arduino Central
Show Control Button
Show Standard Button set 1
Show Standard Button set 2
Show Standard Button set 3
Daher sollte EF1 5A betragen.
Manuelles Testen:
Unterspannungsabschaltung
angezeigt.
Spiralfahrt
            bb.flagCruiseSpiral = true;
double Output = integral;
Schnelle Rückkehr
Abfrage der States
   return BH_RUNNING;
Siehe Bild:
  • 1. 12V vorhanden
  • 2. 5V vorhanden
Out: READ
Out: READ
Out: READ
Out: READ
