Raindancer Firmware (English)
- 1 Download
- 2 Overview
- 4 Optional can be used
- 5 config.h
- 6 QUICK START TO MOW
- 6.1 Errorhandling
- 6.7 Mähmotor Inbetriebnahme
- 6.9 Konfiguration Bluetooth
- 6.11 Erste Testfahrt
- 7 TUNE UP
- 7.2 Charge Service
- 7.3 Watchdog
- 7.5 I2C Bus
- 7.6 RTC
- 7.7 EEPROM
- 7.11 Spiralfahrt
- 7.12 Perimeter Tracking
- 7.13 Schnelle Rückkehr
- 8 Perimeter Sender
- 9 Troubleshooting
Overview
Example: clc.enc
Example: pc.cm,60,30 //drives 60 cm with speed 30 (//drives... does not belong to the command)
Which modes will start when:
Open points
- Dodge objects close to the perimeter (SecondReverse2 in the BHT)
- Program one-sided accessible charging station
Other wishes
- Integrate rain sensor
- SRF08 integration
- GPS map - the mower may not recognize the signal in the middle of the lawn because the signal is too weak. You can then use GPS to see if you are on the lawn area. If you now say that the signal must be detected at least 15m away from the perimeter, you can neglect the signal within the area if the GPS signal indicates that you are on the lawn.
- PCB1.3 with Arduino DUE
- BT module
- 24V power supply
- RTC with EEPROM
#define ARDUMOWER_CHASSIS false #define PARANELLO_CHASSIS false #define RAINDANCER_CHASSIS true
Console Speed:
has to be changed to:
Errorhandling
error //show errormessage
show.hist //show history
A
Enter the command:
Enter the command
clc.mt, 1,150
to make the left wheel turn.
Enter then
clc.mt, 2,150
Enter: clc.v, 30 Moving forward with speed 30% then clc.v, s stop engine then clc.v, -30 drives reverse with speed 30%
Make a mark on a wheel to see how far it turns. pc.a, 360,80 Rotates both wheels forward by 360 degrees with 80% speed if everything is configured correctly. pc.a, -360,80 Rotates both wheels backwards by 360 degrees with 80% speed if everything is configured correctly.
The Position Control can be stoped with the command pc.s
To enable motor monitoring in config.h, set the value CONF_DISABLE_MOTOR_STALL_CHECK to false. #define CONF_DISABLE_MOTOR_STALL_CHECK false
Drive a certain way in cm
pc.cm, 60,30 drives 60cm forward with the speed of 30%
z //mow motor start
t //mow motor stop
Wichtig ist, das CONF_LEFT_COIL_INVERSE und CONF_RIGHT_COIL_INVERSE so konfiguriert werden, dass per.show innerhalb der Spule positive Amplituden anzeigt.
// Orignal Ardumower Bumper Pins #if CONF_DISABLE_BUMPER_SERVICE == false if (( /*diBumperL == LOW &&*/ diBumperR == LOW) && _bumperActivated) { if (flagShowBumper) { errorHandler.setInfo("!03,Bumper deactivated\r\n"); } _bumperActivated = false; //motor.hardStop(); } if ((/*diBumperL == HIGH ||*/ diBumperR == HIGH) && !_bumperActivated) { if (flagShowBumper) { errorHandler.setInfo("!03,Bumper activated\r\n"); } _bumperActivated = true; //motor.hardStop(); } #endif
// Orignal Ardumower Bumper Pins #if CONF_DISABLE_BUMPER_SERVICE == false if (( /*diBumperL == HIGH &&*/ diBumperR == HIGH) && _bumperActivated) { if (flagShowBumper) { errorHandler.setInfo("!03,Bumper deactivated\r\n"); } _bumperActivated = false; //motor.hardStop(); } if ((/*diBumperL == LOW ||*/ diBumperR == LOW && !_bumperActivated) { if (flagShowBumper) { errorHandler.setInfo("!03,Bumper activated\r\n"); } _bumperActivated = true; //motor.hardStop(); } #endif
// Orignal Ardumower Bumper Pins #if CONF_DISABLE_BUMPER_SERVICE == false if (( diBumperL == HIGH && diBumperR == HIGH) && _bumperActivated) { if (flagShowBumper) { errorHandler.setInfo("!03,Bumper deactivated\r\n"); } _bumperActivated = false; //motor.hardStop(); } if ((diBumperL == LOW || diBumperR == LOW && !_bumperActivated) { if (flagShowBumper) { errorHandler.setInfo("!03,Bumper activated\r\n"); } _bumperActivated = true; //motor.hardStop(); } #endif
angezeigt.
Spiralfahrt
if(CONF_ACTVATE_AUTO_SPIRAL) { (a) if(bb.mowMotorSensor.motorUnderHeavyLoad) { if(millis()-bb.lastTimeSpiralStarted > 60000ul) { bb.flagCruiseSpiral = true; } } (b) if( (millis()-bb.lastTimeSpiralStarted > 180000ul) && bb.mowMotorSensor.checkIfUnderLoad() ) { // Alle 3 Minuten Spirale starten wenn motor belastet bb.flagCruiseSpiral = true; } }
if ((millis() - lastTransitionTime) > 1000) { // If more than 1sec inside rotate aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + 10)); bb.motor.R->setSpeed(-25); }
if ((millis() - lastTransitionTime) > 1800) { bb.cruiseSpeed = 25; bb.driveDirection = DD_ROTATECW; bb.motor.L->setSpeed(25); bb.motor.R->setSpeed(-25);
if ((millis() - lastTransitionTime) > 1000) { // If more than 2sec Outside rotate aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); bb.motor.R->setSpeed((bb.cruiseSpeed +5)); }
if ((millis() - lastTransitionTime) > 1500) { // If more than 2.8sec Outside rotate more aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); bb.motor.R->setSpeed((bb.cruiseSpeed +10)); }
if ((millis() - lastTransitionTime) > 1500) { // If more than 2.8sec Outside rotate more aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); bb.motor.R->setSpeed((bb.cruiseSpeed +10)); } if ((millis() - lastTransitionTime) > 2000) { // If more than 3.5sec Outside rotate full bb.cruiseSpeed = 25; bb.driveDirection = DD_ROTATECC; bb.motor.L->setSpeed(-25); bb.motor.R->setSpeed(25); }
if (bb.perimeterSensoren.isLeftOutside() == true) { bb.cruiseSpeed = 25; bb.driveDirection = DD_ROTATECC; bb.motor.L->setSpeed(-25); bb.motor.R->setSpeed(25); waitForRightInside = true; }
Schnelle Rückkehr
virtual NodeStatus onUpdate(Blackboard& bb) { ...
//============================================ // Calculate driven angle every 500ms. //============================================ if (millis() - lastRunAngleCalculation >= 500) { lastRunAngleCalculation = millis(); ... angle = (cmL - cmR) * 57.2957795f / CONF_DISTANCE_BETWEEN_WHEELS_CM; if (flagShowFindTriangleStates) { errorHandler.setInfoNoLog(F("Winkel: %f cmL %f cmR %f\r\n"), angle, cmL, cmR); } }
Abfrage der States
// Check for left curve / right curve / second left curve switch (state) {
case 0: // search for left curve if (angle < -25) { if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s0 set state = 1 Left turn found angle: %f ms: %lu\r\n"), angle, millis()); } bb.motor.startDistanceMeasurementTriangle(); ... state = 1; // Activate triangle searching } break;
case 1: // search for right turn distance = bb.motor.getDistanceInCMForTriangle(); if (distance > 55) { state = 0; if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s1 set state = 0 distance %f > 55 ms: %lu\r\n"), distance, millis()); } } else if (angle > 50) { if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s1 set state = 2 angle %f distance %f < 50\r\n"), angle, distance); } bb.motor.startDistanceMeasurementTriangle(); ... state = 2; } break;
case 2: // search for second left curve distance = bb.motor.getDistanceInCMForTriangle(); if (distance > 50) { state = 0; if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s2 set state = 0 distance %f > 50 ms: %lu\r\n"), distance, millis()); } } else if (angle < -25) { if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s2 set state = 3 angle %f distance %f < -25\r\n"), angle, distance); } bb.motor.startDistanceMeasurementTriangle(); ... state = 3; } break;
case 3: if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s3 set state=0 Cross Lawn Activated\r\n")); } state = 0; return BH_SUCCESS; break;
... } return BH_RUNNING; }
Siehe Bild:
- 1. 12V vorhanden
- 2. 5V vorhanden
