Raindancer Firmware (English)
Version vom 30. Mai 2018, 12:58 Uhr von Roland (Diskussion | Beiträge) (→‎Perimeter Inbetriebnahme)
!!! I am currently translating this side. !!!
Github Download
Overview
Example: clc.enc
Example: pc.cm,60,30       //drives 60 cm with speed 30 (//drives... does not belong to the command)
Which modes will start when:
Open points
  • Stability of the software in the long term. Stand 28.04.2018 Currently, the current software version mowed 63h, has traveled 59km and has rotated 8426 times
  • The line tracking algorithm has been recently optimized for the rear wheel drive chassis. Due to the short distance between coil and the wheels of the original Ardumower chassis, it may be necessary to program another algorithm.
  • Optimization for the original Ardumower chassis (Mowing works very well with the workaround, if necessary, play with the parameters CONF_PER_CORRECTION_ANGLE and CONF_PERIMETER_DRIVE_BACK_CM)
  • Dodge objects close to the perimeter (SecondReverse2 in the BHT)
  • Program one-sided accessible charging station
  • Use RTC to program start at a defined time
Other wishes
  • Integrate rain sensor
  • The charging station is currently only counterclockwise approached.
  • Amplify the signal of the charging station to + -20V voltage stroke
  • SRF08 integration
  • Integrate I2C temperature sensors
  • An external start / stop button that starts or stops mowing
  • Approachthe charging station with GPS. Drive 15m before the charging station on the perimeter and then drive into the charging station..
  • GPS map - the mower may not recognize the signal in the middle of the lawn because the signal is too weak. You can then use GPS to see if you are on the lawn area. If you now say that the signal must be detected at least 15m away from the perimeter, you can neglect the signal within the area if the GPS signal indicates that you are on the lawn.
  • GPS Map - Note where mower has already mowed. Then mow in less mowed areas if necessary.
  • PCB1.3 with Arduino DUE
  • BT module
  • 24V power supply
Optional can be used
  • RTC with EEPROM
#define ARDUMOWER_CHASSIS  false
Console Speed:
has to be changed to:
  #define PWM_FREQUENCY 3900
  #define TC_FREQUENCY 3900
Errorhandling
error     //show errormessage
show.hist   //show history
A
Commissioning of the motors
Enter the command:
Commissioning the encoder
Enter the command
clc.mt, 1,150
to make the left wheel turn.
Enter then
clc.mt, 2,150
Enter:
then
clc.v, s stop engine
then
Drive a certain way in cm
pc.cm, 60,30  drives 60cm forward with the speed of 30%
Mähmotor Inbetriebnahme
z          //mow motor start
t          //mow motor stop
perimeter commissioning
per.resultl for left coil
and
per.resultr for right coil.
Beispiel per.resultl
End the output with h.
Konfiguration Bluetooth
Einstellen Arduino Central
Show Control Button
Show Standard Button set 1
Show Standard Button set 2
Show Standard Button set 3
Daher sollte EF1 5A betragen.
Manuelles Testen:
Unterspannungsabschaltung
angezeigt.
Spiralfahrt
            bb.flagCruiseSpiral = true;
double Output = integral;
Schnelle Rückkehr
Abfrage der States
   return BH_RUNNING;
Siehe Bild:
  • 1. 12V vorhanden
  • 2. 5V vorhanden
Out: READ
Out: READ
Out: READ
Out: READ
