Raindancer Firmware (English)
Version vom 31. Mai 2018, 18:26 Uhr von Roland (Diskussion | Beiträge) (→‎Mower bleibt stehen)
!!! I am currently translating this side. !!! English is not my native language. If you don't understand something or find a mistake, please inform me on the forum (name: Roland) or correct the mistake by yourself.
Github Download
Overview
Example: clc.enc
Example: pc.cm,60,30       //drives 60 cm with speed 30 (//drives... does not belong to the command)
Which modes will start when:
Open points
  • Stability of the software in the long term. Stand 28.04.2018 Currently, the current software version mowed 63h, has traveled 59km and has rotated 8426 times
  • The line tracking algorithm has been recently optimized for the rear wheel drive chassis. Due to the short distance between coil and the wheels of the original Ardumower chassis, it may be necessary to program another algorithm.
  • Optimization for the original Ardumower chassis (Mowing works very well with the workaround, if necessary, play with the parameters CONF_PER_CORRECTION_ANGLE and CONF_PERIMETER_DRIVE_BACK_CM)
  • Dodge objects close to the perimeter (SecondReverse2 in the BHT)
  • Program one-sided accessible charging station
  • Use RTC to program start at a defined time
Other wishes
  • Integrate rain sensor
  • The charging station is currently only counterclockwise approached.
  • Amplify the signal of the charging station to + -20V voltage stroke
  • SRF08 integration
  • Integrate I2C temperature sensors
  • An external start / stop button that starts or stops mowing
  • Approachthe charging station with GPS. Drive 15m before the charging station on the perimeter and then drive into the charging station..
  • GPS map - the mower may not recognize the signal in the middle of the lawn because the signal is too weak. You can then use GPS to see if you are on the lawn area. If you now say that the signal must be detected at least 15m away from the perimeter, you can neglect the signal within the area if the GPS signal indicates that you are on the lawn.
  • GPS Map - Note where mower has already mowed. Then mow in less mowed areas if necessary.
  • PCB1.3 with Arduino DUE
  • BT module
  • 24V power supply
Optional can be used
  • RTC with EEPROM
#define ARDUMOWER_CHASSIS  false
Console Speed:
has to be changed to:
  #define PWM_FREQUENCY 3900
  #define TC_FREQUENCY 3900
Errorhandling
error     //show errormessage
show.hist   //show history
A
Commissioning of the motors
Enter the command:
Commissioning the encoder
Enter the command
clc.mt, 1,150
to make the left wheel turn.
Enter then
clc.mt, 2,150
Enter:
then
clc.v, s stop engine
then
Drive a certain way in cm
pc.cm, 60,30  drives 60cm forward with the speed of 30%
Mowmotor commissioning
z          //mow motor start
t          //mow motor stop
Perimeter Commissioning
per.resultl for left coil
and
per.resultr for right coil.
Beispiel per.resultl
End the output with h.
Configure Bluetooth
Configure Arduino Central
Show Control Button
Show Standard Button set 1
Show Standard Button set 2
Show Standard Button set 3
Select CR
Select NL
First test drive
Put the robot inside the perimeter loop. Check the perimeter signal again with show.per. Disable perimeter output with h or show.per output
The original Ardumower chassis does not provide a standard solution for bumpers. Since most users create their own solutions here, the software must be adapted to the respective requirement of the respective user. Modularizing services makes this very easy to customize.
Since depending on the application both bumper pins or only one is used, you may have to reprogram the bumper service on your own requirements. The bumper service is programmed in bumperSensor.cpp.
The following lines should be taken into account.
The above lines activate the bumper when the bumper pin goes high and turn it off when it goes low. This is the configuration for a Hall sensor. When the magnet is above the Hall sensor, it will turn on the Open Collector output. The pin is thus at GND. In the current configuration, this means the bumper is not 'pressed.
Furthermore, only the right bumper connector is used. If you also want to use the left port, you have to uncomment "diBumperL == LOW &&" and "diBumperL == LOW ||" .
If you want to connect a switch on the right bumper connector, which is closed when the bumper is triggered (ie PIN on GND means bumper active), you have to use the following code (currently not tested)
With two switches:
The line //motor.hardStop (); is currently no longer used. Because when using a swinging Bumperchassis the motor current must not immediately be set to 0. There is still 1-2cm clearance available. But can be inserted if the bumper is triggered, if the wheels spin when bumping. (currently not tested)
Annotation:
Therefore, EF1 should be 5A.
Use without charging station
Put in the charging station
Manual testing:
Enter the command:
Enable relay:
Disable relay:
Undervoltage Shutdown
With the command
Set mower motor current
Archimedean Apirale
            bb.flagCruiseSpiral = true;
double Output = integral;
The command
stops the test.
With the command
set.lfki, 1.1
Fast return
Query the States
   return BH_RUNNING;
See image:
  • 1. 12V available
  • 2. 5V available
Mower stops
Problem: Mower stopped, cause was probably the transmitter. There just lights still the two left LEDs. Transmitter off and on again turned on, 4 LEDs back to green and then it went again.
Possibility A) The transmitter is on for more than 3 hours without the robot returning to the station. Then the transmitter turns off the perimeter signal.
Possibility b) Since this was not on, the nano seems to have hung up. If that happens again, I would swap the China Nano for an original Arduino Nano. Since the software has been running for me for a year, I do not assume that this is the cause. I had used cheap nanos before. They were not really frequency stable with me, which is necessary for the transmitter however. Now I have an original in it.
Out: READ
Out: READ
Out: READ
Out: READ
