Raindancer Firmware (English)
!!! I am currently translating this side. !!! English is not my native language. If you don't understand something or find a mistake, please inform me on the forum (name: Roland) or correct the mistake by yourself.
- 1 Download
- 2 Overview
- 4 Optional can be used
- 5 config.h
- 6 QUICK START TO MOW
- 6.1 Errorhandling
- 6.7 Mowmotor commissioning
- 6.8 Perimeter Commissioning
- 6.9 Configure Bluetooth
- 6.10 Configure Arduino Central
- 6.11 First test drive
- 7 TUNE UP
- 7.2 Charge Service
- 7.3 Watchdog
- 7.4 Undervoltage Shutdown
- 7.5 I2C Bus
- 7.6 RTC
- 7.7 EEPROM
- 7.9 Set mower motor current
- 7.11 Archimedean Apirale
- 7.12 Perimeter Tracking
- 7.13 Fast return
- 7.14 Mowing zones between adjacent surfaces
- 7.15 Laying the Perimeter Cable at Corners
- 8 Perimeter Sender
- 9 Troubleshooting
Overview
Example: clc.enc
Example: pc.cm,60,30 //drives 60 cm with speed 30 (//drives... does not belong to the command)
Which modes will start when:
Open points
- Dodge objects close to the perimeter (SecondReverse2 in the BHT)
- Program one-sided accessible charging station
Other wishes
- Integrate rain sensor
- SRF08 integration
- GPS map - the mower may not recognize the signal in the middle of the lawn because the signal is too weak. You can then use GPS to see if you are on the lawn area. If you now say that the signal must be detected at least 15m away from the perimeter, you can neglect the signal within the area if the GPS signal indicates that you are on the lawn.
- PCB1.3 with Arduino DUE
- BT module
- 24V power supply
- RTC with EEPROM
#define ARDUMOWER_CHASSIS false #define PARANELLO_CHASSIS false #define RAINDANCER_CHASSIS true
Console Speed:
has to be changed to:
Errorhandling
error //show errormessage
show.hist //show history
A
Enter the command:
Enter the command
clc.mt, 1,150
to make the left wheel turn.
Enter then
clc.mt, 2,150
Enter:
then
clc.v, s stop engine
then
Drive a certain way in cm
pc.cm, 60,30 drives 60cm forward with the speed of 30%
z //mow motor start
t //mow motor stop
per.resultl for left coil
and
per.resultr for right coil.
End the output with h.
Configure Bluetooth
Lets start:
Select CR
Select NL
First test drive
The original Ardumower chassis does not provide a standard solution for bumpers. Since most users create their own solutions here, the software must be adapted to the respective requirement of the respective user. Modularizing services makes this very easy to customize.
Since depending on the application both bumper pins or only one is used, you may have to reprogram the bumper service on your own requirements.
The bumper service is programmed in bumperSensor.cpp.
The following lines should be taken into account.
The above lines activate the bumper when the bumper pin goes high and turn it off when it goes low. This is the configuration for a Hall sensor. When the magnet is above the Hall sensor, it will turn on the Open Collector output. The pin is thus at GND. In the current configuration, this means the bumper is not 'pressed.
Furthermore, only the right bumper connector is used. If you also want to use the left port, you have to uncomment "diBumperL == LOW &&" and "diBumperL == LOW ||" .
If you want to connect a switch on the right bumper connector, which is closed when the bumper is triggered (ie PIN on GND means bumper active), you have to use the following code (currently not tested)
With two switches:
The line //motor.hardStop (); is currently no longer used. Because when using a swinging Bumperchassis the motor current must not immediately be set to 0. There is still 1-2cm clearance available. But can be inserted if the bumper is triggered, if the wheels spin when bumping. (currently not tested)
Annotation:
Use without charging station
Put in the charging station
Enter the command:
Enable relay:
Disable relay:
With the command
Archimedean Apirale
bb.flagCruiseSpiral = true;
integral = integral + (Ki*error); // the value error is a constant and has the value -1 if the coil is outside the perimeter. double Output = integral;
bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); // note: output is negative bb.motor.R->setSpeed((bb.cruiseSpeed));
The command
stops the test.
With the command
set.lfki, 1.1
Fast return
Query the States
... } return BH_RUNNING; }
See image:
area,x // where x is the path to be traveled in m.
- 1. 12V available
- 2. 5V available
- 3. Green when the interrupt which produces the signal is running (red LED not available because of wrong pin at Nano). Off when charging.
- 4. Green when a current flows through the perimeter, red when no current is flowing (perimeter interrupted) or very little current because of high protective resistor. Off when charging.
- 5. Yellow the robot is charging. Perimeter signal is switched off. LED 2 and 4 off.
Mower stops
