Diodes with correct plug in direction
Cut the socket strip at a pin not in between
Solder the socket strips for the nano
Solder the terminal blocks
Solder socket strips for INA and mc33926 motor drive
Solder pins to DC/DC converter and then put a socket on
Put the DC/DC converter on the board
Flip the board and solder the sockets
Sockets for DC/DC converter soldered
Put in the pins for the INA
Install the INA and solder it
Put in the pins fot the mc33926 motor drive
Install the motor driver and solder it. Solder also the two right pins. I didn't it here because I want to connect a second external power supply
Solder the terminal blocks. You have two pins soldered between the terminal blocks
Finished. On the picture you see on the right side 3 terminal blocks installed. You have only two terminal blocks installed and in the middle in between the terminal blocks are pin soldered
