Raindancer Firmware (Deutsch)
- 1 Download
- 2 Überblick
- 5 config.h
- 6 QUICK START TO MOW
- 6.1 Errorhandling
- 6.7 Mähmotor Inbetriebnahme
- 6.9 Konfiguration Bluetooth
- 6.11 Erste Testfahrt
- 7 TUNE UP
- 7.2 Charge Service
- 7.3 Watchdog
- 7.5 I2C Bus
- 7.6 RTC
- 7.7 EEPROM
- 7.11 Spiralfahrt
- 7.12 Perimeter Tracking
- 7.13 Schnelle Rückkehr
- 7.16 Temperatur Sensor
- 7.17 Shutdown Service
- 8 Perimeter Sender
- 9 Ladestation
- 10 Troubleshooting
- Regensensor einbinden
- SRF08 einbinden
- PCB1.3 mit Arduino DUE
- Original Ardumower Mähmotor
- BT Modul
- 24V Spanungsversorgung
- RTC mit EEPROM
- Durchfahrende Ladestation
#define CONF_DISABLE_PERIMETER_SERVICE false // Disables perimeter sensor #define CONF_DISABLE_RTC_SERVICE true // Disables rtc sensor #define CONF_DISABLE_EEPROM_SERVICE true // Disables EEPROM requests #define CONF_DISABLE_BATTERY_SERVICE true // Disables battery sensor #define CONF_DISABLE_CHARGE_SERVICE true // Disables charge system service #define CONF_DISABLE_RAIN_SERVICE true // Disables rain sensor #define CONF_DISABLE_DHT_SERVICE true // Disables temp sensor
Errorhandling
error //show errormessage
show.hist //show history
A
clc.v,s Motor stoppen
z //mow motor start
t //mow motor stop
#define CONF_ESCAPEDIR_DEPENDING_ON_BUMPER false // if set to true, the robot rotates in the opposite direction of the activated bumper. If false, the escape direction is random. // only set to true if you use a bumper for left and a bumper for right.
angezeigt.
Spiralfahrt
if(CONF_ACTVATE_AUTO_SPIRAL) { (a) if(bb.mowMotorSensor.motorUnderHeavyLoad) { if(millis()-bb.lastTimeSpiralStarted > 60000ul) { bb.flagCruiseSpiral = true; } } (b) if( (millis()-bb.lastTimeSpiralStarted > 180000ul) && bb.mowMotorSensor.checkIfUnderLoad() ) { // Alle 3 Minuten Spirale starten wenn motor belastet bb.flagCruiseSpiral = true; } }
if ((millis() - lastTransitionTime) > 1000) { // If more than 1sec inside rotate aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + 10)); bb.motor.R->setSpeed(-25); }
if ((millis() - lastTransitionTime) > 1800) { bb.cruiseSpeed = 25; bb.driveDirection = DD_ROTATECW; bb.motor.L->setSpeed(25); bb.motor.R->setSpeed(-25);
if ((millis() - lastTransitionTime) > 1000) { // If more than 2sec Outside rotate aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); bb.motor.R->setSpeed((bb.cruiseSpeed +5)); }
if ((millis() - lastTransitionTime) > 1500) { // If more than 2.8sec Outside rotate more aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); bb.motor.R->setSpeed((bb.cruiseSpeed +10)); }
if ((millis() - lastTransitionTime) > 1500) { // If more than 2.8sec Outside rotate more aggressive bb.motor.L->setSpeed((bb.cruiseSpeed + Output)); bb.motor.R->setSpeed((bb.cruiseSpeed +10)); } if ((millis() - lastTransitionTime) > 2000) { // If more than 3.5sec Outside rotate full bb.cruiseSpeed = 25; bb.driveDirection = DD_ROTATECC; bb.motor.L->setSpeed(-25); bb.motor.R->setSpeed(25); }
if (bb.perimeterSensoren.isLeftOutside() == true) { bb.cruiseSpeed = 25; bb.driveDirection = DD_ROTATECC; bb.motor.L->setSpeed(-25); bb.motor.R->setSpeed(25); waitForRightInside = true; }
Schnelle Rückkehr
virtual NodeStatus onUpdate(Blackboard& bb) { ...
//============================================ // Calculate driven angle every 500ms. //============================================ if (millis() - lastRunAngleCalculation >= 500) { lastRunAngleCalculation = millis(); ... angle = (cmL - cmR) * 57.2957795f / CONF_DISTANCE_BETWEEN_WHEELS_CM; if (flagShowFindTriangleStates) { errorHandler.setInfoNoLog(F("Winkel: %f cmL %f cmR %f\r\n"), angle, cmL, cmR); } }
Abfrage der States
// Check for left curve / right curve / second left curve switch (state) {
case 0: // search for left curve if (angle < -25) { if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s0 set state = 1 Left turn found angle: %f ms: %lu\r\n"), angle, millis()); } bb.motor.startDistanceMeasurementTriangle(); ... state = 1; // Activate triangle searching } break;
case 1: // search for right turn distance = bb.motor.getDistanceInCMForTriangle(); if (distance > 55) { state = 0; if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s1 set state = 0 distance %f > 55 ms: %lu\r\n"), distance, millis()); } } else if (angle > 50) { if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s1 set state = 2 angle %f distance %f < 50\r\n"), angle, distance); } bb.motor.startDistanceMeasurementTriangle(); ... state = 2; } break;
case 2: // search for second left curve distance = bb.motor.getDistanceInCMForTriangle(); if (distance > 50) { state = 0; if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s2 set state = 0 distance %f > 50 ms: %lu\r\n"), distance, millis()); } } else if (angle < -25) { if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s2 set state = 3 angle %f distance %f < -25\r\n"), angle, distance); } bb.motor.startDistanceMeasurementTriangle(); ... state = 3; } break;
case 3: if (flagShowFindTriangleStates) { errorHandler.setInfo(F("!03,s3 set state=0 Cross Lawn Activated\r\n")); } state = 0; return BH_SUCCESS; break;
... } return BH_RUNNING; }
Siehe Bild:
Temperatur Sensor
#define DHTTYPE DHT22
temp.show
Shutdown Service
Wenn der shutdown service aktiviert wird, schaltet dieser den Strom über die Undervolatageprotection ab. Wenn ein Raspberry PI an den USB Port angeschlossen ist kann CONF_WAIT_FOR_PI_SHUTDOWN = true gesetzt werden. Dann wartet die Software 50 Sekunden bis zur Abschaltung. Es wird jede Sekunde $PwrOff und ein Countdown zu dem PI geschickt, so dass dieser herunterfahren kann.
Mit dem Befehl:
poweroff
- 1. 12V vorhanden
- 2. 5V vorhanden
Ladestation
eingestellt werden. Dann fährt er bei geringer Batteriespannung zum Perimeter und bleibt stehen.
Kopfladestation
Wird eine Kopfladestation verwendet ist darauf zu achten , dass die Kontakte mindestens 2 cm nachgeben können wenn der Mower dagegen fährt. Besser wären 4 cm. Weiterhin ist zu beachten, dass der Anpressdruck der Kontaket ausreichend ist.
gohome
tpt
Zum verlassen der Ladestation
area,0
Durchgangs Ladestation
