Raindancer Firmware (English)
Version vom 31. Juli 2018, 10:30 Uhr von Roland (Diskussion | Beiträge) (→‎Head charging station)
Github Download
Overview
Example: clc.enc
Which modes will start when:
Open points
  • Stability of the software in the long term. Stand 28.04.2018 Currently, the current software version mowed 63h, has traveled 59km and has rotated 8426 times
  • The line tracking algorithm has been recently optimized for the rear wheel drive chassis. Due to the short distance between coil and the wheels of the original Ardumower chassis, it may be necessary to program another algorithm.
  • Optimization for the original Ardumower chassis (Mowing works very well with the workaround, if necessary, play with the parameters CONF_PER_CORRECTION_ANGLE and CONF_PERIMETER_DRIVE_BACK_CM)
  • Use RTC to program start at a defined time
Other wishes
  • Integrate rain sensor
  • The charging station is currently only counterclockwise approached.
  • Amplify the signal of the charging station to + -20V voltage stroke
  • SRF08 integration
  • Integrate I2C temperature sensors
  • An external start / stop button that starts or stops mowing
  • Approachthe charging station with GPS. Drive 15m before the charging station on the perimeter and then drive into the charging station..
  • GPS Map - Note where mower has already mowed. Then mow in less mowed areas if necessary.
  • PCB1.3 with Arduino DUE
  • BT module
  • 24V power supply
Optional can be used
  • RTC with EEPROM
Console Speed:
has to be changed to:
  #define PWM_FREQUENCY 3900
  #define TC_FREQUENCY 3900
Errorhandling
error     //show errormessage
show.hist   //show history
A
Commissioning of the motors
Enter the command:
Commissioning the encoder
Enter the command
clc.mt, 1,150
to make the left wheel turn.
Enter then
clc.mt, 2,150
Enter:
then
clc.v, s stop engine
then
Drive a certain way in cm
Mowmotor commissioning
z          //mow motor start
t          //mow motor stop
Perimeter Commissioning
per.resultl for left coil
and
per.resultr for right coil.
Beispiel per.resultl
End the output with h.
Configure Bluetooth
Configure Arduino Central
Show Control Button
Show Standard Button set 1
Show Standard Button set 2
Show Standard Button set 3
Select CR
Select NL
First test drive
Put the robot inside the perimeter loop. Check the perimeter signal again with show.per. Disable perimeter output with h or show.per output
Determine if the bumper is aktive if the pin is connected to GND:
Annotation:
Therefore, EF1 should be 5A.
Use without charging station
Put in the charging station
Manual testing:
Enter the command:
Enable relay:
Disable relay:
Undervoltage Shutdown
With the command
Set mower motor current
Archimedean Apirale
            bb.flagCruiseSpiral = true;
double Output = integral;
The command
stops the test.
With the command
set.lfki, 1.1
Fast return
Query the States
   return BH_RUNNING;
See image:
Temperature Sensor
#define DHTTYPE DHT22
temp.show
Shutdown Service
GPS Service
set.cco, 1
set.cco,0
Enable internal calculation
With
gps.show
The point can then be taken from the line! 03,$GPRMC,lat:53.08744800,N lon:9.44867700,E. Here for Latitude = 54.087448 and Longitude = 10.448677.
  • 1. 12V available
  • 2. 5V available
Charging Station
Head charging station
With the command
gohome
tpt
area,0
Through Charging Station
With the command
gohome
tpt
Mower stops
Out: READ
Out: READ
Out: READ
Out: READ
