Ardumower Sunray
400px
Demo video: coming soon
  • Optimized for Arduino Due
  • Ardumower PCB 1.3 (incl. MC33926 motor drivers)
  • Arduino Due
  • SimpleRTK2B - starter kit LR IP67
  • Bluetooth BLE module (CC2540) and a smartphone (Android/iOS)
Install Bluetooth 4.0/BLE module as shown below.
IMPORTANT: Verify the pinout of your BLE module is matching your PCB pinout (shown at the PCB back side)!
PCB1.3 GPS
  1. Make sure you have the simpleRTK2B marked as 'BASE' in your hands (look at simpleRTK2B PCB label at backside!)
  2. Connect Xbee LongRange antenna
  3. Connect GPS multifrequency antenna
  4. Connect USB 5v to power base module
  1. Make sure you have the simpleRTK2B marked as 'ROVER' in your hands (look at simpleRTK2B PCB label at backside!)
  2. Connect XBee LongRange antenna
Firmware
3. Start Arduino IDE, and upload the sketch to your PCB1.3.
1.1. Download Viewer App:
How does it work
  1. coming soon
Discussion / forum thread
  1. coming soon
