Ardumower Sunray
Version vom 24. Januar 2020, 15:00 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Bluetooth BLE module)
400px
Demo video: coming soon
  • Optimized for Arduino Due
  • Ardumower PCB 1.3 (incl. MC33926 motor drivers)
  • Arduino Due
  • SimpleRTK2B - starter kit LR IP67
  • Bluetooth BLE module (CC2540) and a smartphone (Android/iOS)
Install Bluetooth 4.0/BLE module on Ardumower PCB1.3 as shown below.
IMPORTANT: Verify the pinout of your BLE module is matching your PCB pinout (shown at the PCB back side)!
PCB1.3 GPS
  1. Make sure you have the simpleRTK2B marked as 'BASE' in your hands (look at simpleRTK2B PCB label at backside!)
  2. Connect Xbee LongRange antenna
  3. Connect GPS multifrequency antenna
  4. Connect USB 5v to power base module
  1. Make sure you have the simpleRTK2B marked as 'ROVER' in your hands (look at simpleRTK2B PCB label at backside!)
  2. Connect XBee LongRange antenna
Rover configuration
1. Connect rover module via USB to your PC.
3. Choose 'Receiver->Connection' and choose your rover.
4. Choose 'View->Configuration View'. Choose configuration message 'MSG (Messages)' and select one message after the other in the list (0A-37 MON-HW3, 0A-09 MON-HW, etc.). For each message, make sure the selected message is NOT activated for UART1. Example for message '01-22 NAV-CLOCK':
5. Finally only activate message '01-3C NAV-RELPOSNED' for UART1.
Firmware
3. Start Arduino IDE, and upload the sketch to your PCB1.3.
1.1. Download Viewer App:
How does it work
  1. coming soon
Discussion / forum thread
  1. coming soon
