Ardumower Sunray
Version vom 24. Januar 2020, 18:58 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Rover configuration (messages))
Ardumower Sunray is an alternative Firmware (experimental) for the Ardumower. It uses RTK GPS to localize cm-precise without a perimeter wire. It requires PCB1.3, Arduino Due, ArduSimpleRTK kit and a phone (Android/iOS).
600px
Demo video: coming soon
  • Optimized for Arduino Due
400px PCB
9. Choose configuration message 'CFG (Configuration)' and click on 'Send' to make the configuration in the rover persistent.
10. IMPORTANT: Disconnect USB cable from rover module!
Firmware (Arduino Code)
Discussion / forum thread
