Ardumower Sunray
Version vom 25. Januar 2020, 06:16 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Rover configuration (messages))
Ardumower Sunray is an alternative Firmware (experimental) for the Ardumower. It uses RTK GPS to localize cm-precise without a perimeter wire. It requires PCB1.3, Arduino Due, ArduSimple RTK kit, Bluetooth BLE and a phone (Android/iOS).
600px
Demo video: coming soon
  • Optimized for Arduino Due
400px PCB
9. Choose configuration message 'CFG (Configuration)' and click on 'Send' to make the configuration in the rover persistent.
10. Verify that the configuration is persistent in the rover module - disconnect the rover module and reconnect. Then go all previous steps and verify the configuration is still present.
Firmware (Arduino Code)
Discussion / forum thread
