Ardumower Sunray
NOTE: everything here is still in development! Use Azurit Firmware instead if you need a working firmware...
Demo video: coming soon
- Optimized for Arduino Due
- Arduino Due
- Bluetooth BLE UART module (CC2540) and a smartphone (Android/iOS)
Firmware (Arduino Code)
Both, the robot's odometry and RTK are used to localized the robot. There it is important to verify that the odometry is working correctly:
