Ardumower Sunray
Version vom 29. Januar 2020, 09:37 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Rover configuration (messages))
NOTE: everything here is still in development! Use Azurit Firmware instead if you need a working firmware...
600px
Demo video: coming soon
  • Optimized for Arduino Due
400px PCB
Firmware (Arduino Code)
Both, the robot's odometry and GPS-RTK are used to localized the robot. Therefore, it is important to verify that the odometry is working correctly as shown below:
GPS (invalid, float, fix)
Discussion / forum thread
