Ardumower Sunray
Warning.png NOTE: everything here is already working but in early prototype phase! Use Azurit Firmware instead if you need a firmware with more features...
Demo video: coming soon
  • Optimized for Arduino Due
  • Incomplete (Sunray is 'work in progress') - features like 'exclusion areas' and 'obstacle avoidance' are going to be added soon.
RTK-GPS uses two GPS receivers, one for the reference antenna (base) and one for the robot mower (rover) which both communicate in realtime via radio modules. The base constantly sends correction data so the rover can compute its cm-precise position. In the RTK-GPS kit, everything required (receivers, radios, antennas etc.) is included.
To be able to use RTK-GPS, your robot mower should have a good view to the sky at all locations. RTK-GPS will NOT work directly near walls, under large trees, in buildings etc.
PCB     PCB
400px PCB
Firmware (Arduino Code)
GPS (invalid, float, fix)
Discussion / forum thread
