Ardumower Sunray
Warning.png WARNING: everything here is already working but in early prototype phase!
Use Azurit Firmware instead if you need a firmware with more features...
Demo video
  • Optimized for Arduino Due
  • Incomplete (Sunray is 'work in progress') - features like 'exclusion areas' and 'obstacle avoidance' are going to be added soon.
  • Experimental (never run your Ardumower unattended with this firmware)
PCB     PCB
400px PCB
PCB     PCB
Firmware (Arduino Code)
GPS (invalid, float, fix)
Discussion / forum thread
