Ardumower Sunray
Ardumower Sunray is an alternative Firmware (experimental) for the Ardumower DIY robotic system. It uses RTK GPS to localize cm-precise without a perimeter wire. It requires PCB1.3, Arduino Due, ublox ZED-F9P RTK kit, Bluetooth BLE and a phone (Android/iOS).
Warning.png WARNING: everything here is already working but in early prototype phase!
Use Azurit Firmware instead if you need a firmware with more features...
600px Ardumower sunray app.jpg Video.png DEMO VIDEO
  • Optimized for Arduino Due
  • Incomplete (Sunray is 'work in progress') - features like 'exclusion areas' and 'obstacle avoidance' are going to be added soon.
  • Experimental (never run your Ardumower unattended with this firmware)
PCB     PCB
400px PCB
PCB     PCB
Firmware (Arduino Code)
GPS (invalid, float, fix)
Discussion / forum thread
