Ardumower Sunray
Version vom 4. Februar 2020, 23:23 Uhr von Alexanderg (Diskussion | Beiträge) (→‎How the waypoints are generated)
Ardumower Sunray is an alternative Firmware (experimental) for the Ardumower DIY robotic mower system. It uses RTK GPS to localize cm-precise without a perimeter wire. It requires Ardumower PCB1.3, Arduino Due, ArduSimple RTK kit, Bluetooth BLE and a phone (Android/iOS).
Warning.png WARNING: everything here is already working but in early prototype phase!
600px Ardumower sunray app.jpg Video.png DEMO VIDEO
  • Optimized for Arduino Due
  • Incomplete (Sunray is 'work in progress') - features like 'exclusion areas' and 'obstacle avoidance' are going to be added soon.
  • Experimental (never run your Ardumower unattended with this firmware)
PCB     PCB
400px PCB
PCB     PCB
Firmware (Arduino Code)
GPS (invalid, float, fix)
Discussion / forum thread
600px
