Ardumower Sunray
Version vom 5. Februar 2020, 16:56 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Significant changes compared to Azurit Firmware)
This page describes how to add RTK GPS to your Ardumower DIY robotic mower system using Sunray Firmware and a RTK GPS kit.
Ardumower Sunray is an alternative Firmware (experimental) for the Ardumower DIY robotic mower system. It uses RTK GPS to localize cm-precise without a perimeter wire. It requires Ardumower PCB1.3, Arduino Due, ArduSimple RTK kit, Bluetooth BLE and a phone (Android/iOS).
Ardumower sunray.jpg Ardumower sunray app.jpg Video.png DEMO VIDEO
  • Optimized for Arduino Due
  • Warning.png Incomplete (Sunray is 'work in progress') - features like 'obstacle avoidance' are going to be added soon.
PCB     PCB
400px PCB
PCB     PCB
Firmware (Arduino Code)
GPS (invalid, float, fix)
Discussion / forum thread
600px
