Ardumower Sunray
'Mows like on rails...' This is an RTK GPS-based mower that you can build yourself! The best thing is: Ardumower RTK doesn't need a perimeter wire as it uses (cm-precise) RTK GPS.
- 1 Requirements (environment and hardware)
- 2 Significant changes compared to Ardumower's initial firmware (Azurit)
- 3 Bluetooth BLE UART module
- 4 PCB1.3 GPS pin fix
- 5 PCB1.3 odometry divider
- 6 RTK base
- 7 RTK rover
- 8 Rover configuration (messages)
- 9 Firmware (Arduino Code)
- 10 Phone App
- 11 Odometry test
- 12 RTK GPS test (invalid, float, fix)
- 13 Discussion / forum thread
- 14 How the waypoints are generated
- Optimized for Arduino Due
