Ardumower Sunray
'Mows like on rails...' This is an RTK GPS-based mower that you can build yourself! The best thing is: Ardumower RTK doesn't need a perimeter wire as it uses (cm-precise) RTK GPS.
- 1 What is RTK and what are the requirements (environment and hardware)
- 2 Significant changes compared to Ardumower's initial firmware (Sunray vs. Azurit)
- 3 Installation steps
- 4 Bluetooth BLE UART module
- 5 PCB1.3 GPS pin fix
- 6 PCB1.3 odometry divider
- 7 RTK base
- 8 RTK rover
- 9 Rover configuration (messages)
- 10 Firmware (Arduino Code)
- 11 Phone App
- 12 Odometry test
- 13 RTK GPS test (invalid, float, fix)
- 14 Discussion / forum thread
- 15 How the waypoints are generated
- Optimized for Arduino Due
