Ardumower Sunray
PCB     PCB
  • Optimized for Arduino Due
400px PCB
PCB     PCB
10. Improving position solution robustness: for robust position solutions (FIX), you will need to install a ground plane (10x10cm) for the patch antenna. Connect this antenna to GND and place the patch antenna on top of it like shown below. This will get you most robust position results.
Discussion / forum thread
600px
