Ardumower Sunray
- 1 What is RTK and what are the requirements (environment and hardware)
- 2 Significant changes compared to Ardumower's initial firmware (Sunray vs. Azurit)
- 3 Installation steps
- 4 Bluetooth BLE UART module
- 5 PCB1.3 GPS pin fix
- 6 PCB1.3 odometry divider
- 7 RTK base
- 8 RTK rover
- 9 Rover configuration (messages)
- 10 Download, Arduino Code, Firmware
- 11 Phone App
- 12 Odometry test
- 13 RTK GPS test (invalid, float, fix)
- 14 Discussion / forum thread
- 15 How the waypoints are generated
- Optimized for Arduino Due
6. Improving position solution robustness: for robust position solutions (FIX), you will need to install a (conductive) ground plane (10x10cm) for the patch antenna. Install the patch antenna on top of it like shown below. This will get you most robust position results.
10. Improving position solution robustness: for robust position solutions (FIX), you will need to install a (conductive) ground plane (10x10cm) for the patch antenna. Connect this ground plane to GND and place the patch antenna on top of it like shown below. This will get you most robust position results.
