Bluetooth
Version vom 27. September 2014, 11:29 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Android first time use)
The Ardumower can be controlled via your phone (Anrdoid). On the phone, you'll need the App 'pfodApp'. Alternatively, you can use the App 'ArduRemote'.
The phone menu includes:
  • Status information (battery voltage, charging current etc.)
  • Settings (Timer etc.)
  • Calibration (Motor, IMU etc.)
  • Remote control (Start/Stop, Switching on/off mower motor, blade modulation etc.)
Bluetooth module
On the robot, you'll need a Bluetooth module. Depending on the desired range, you can use different Bluetooth classes: -Bluetooth class 2 (up to approx. 50m range), e.g. HC03/04/05/06 -Bluetooth class 1 (up to approx. 100m range), e.g. BTM220, requires additional circuit
Bluetooth HC-05
Steps
  1. Paring: On the Android device, choose symbol "Settings" (via Android menu). Now choose "Wirless and Networks->Bluetooth Settings" and "Find device". Finally, choose "pair with this device" and enter your pin (very often "1234"). The Bluetooth module should now appear as "paired".
  2. 123
Setting baud rate
Blueooth module and Arduino Mega must use the same baud rate - The baud rate of the BT module can be changed via serial console - enter the serial console in the Arduino IDE, and choose baud rate 19200, then choose 'd' to enter the menu.
  1. menu demo v0.8.8
  2. menu demo v0.8.8
  3. tutorial video
