Chassis (English)
Version vom 22. Juni 2020, 20:43 Uhr von FelixP (Diskussion | Beiträge) (→Assembly: required tools)
- Wheels: 250mm diameter
- Free wheel: 125mm diameter
- Battery: Lithium-Ion 29.4V
- Max. incline: approx. 30%
- Overall impression
- Loundness test
- Gear motor test
- Gear motor hardness test
- Mowing motor hardness test
- Robot releases itself
- Plastic blades test
- Rain sensor test
- 3D simulation
Required Tools
- Screw driver
- Different Torx screw driver
Optional Tools
- Round and flat file
- Electric padsaw
