Perimeter wire
Version vom 5. Oktober 2014, 20:45 Uhr von StefanM (Diskussion | Beiträge) (→‎Perimeter v2 (for SVN version, recommended))
So, here's the sender:
Functional test
Receiver
Principle:
'Arduino sound sensor'
LM386 amplifier
Functional test
Choice for coil
Arrangement of coils
Layout of the wire
  1. Perimeter stop test
  2. Perimeter tracking test
While crossing the perimeter loop, something interesting happens: signal changes polarity, that means negative and positive voltages reverse each other. By using this principle, crossing the perimeter wire will be detected. The robot knows its current perimeter state all the time (inside/ouside). As with perimeter v1, we will again use a motor driver to generate the signal and an operation amplifier to amplify the received signal.
Principle:
  1. Amplify perimeter coil signal using OPAMP
  2. ADC sampling using Arduino
  3. Signal filterung and detection using a digital filter (Matched filter algorithmn).
  4. Evaluation of filter output
Simulation
You can see how it works:
The motor driver is driven by 3.2 Khz (two pulse widths 4.8 Khz and 2.4 Khz). The circuit draws max. 20W (12V, 1.7A). We use a motor driver with integrated current limiting and thermal switch-off (e.g. MC33926).
sender circuit:
               |---------o-- GND
               |---------o-- Arduino +5V
Software
  1. define USE_POT for adjust if use an Poti to adjust the Power Out of the Perimter
and
  1. define USE_CHG_CURRENT if you set it to 1 the Perimter shuts off while the Mower is Charging, if the Charger is not
connected set to 0
Receiver
receiver circuit:
Flux directions
ADC calibration
Note: Run the ADC calibration once ("pfodApp->ADC Calibration"), so that the received signal is symmetric around zero. The Perimeter Transmiter must be off while Calibration.
Diagnostics
Sender status LED (Arduino LED):
  • blinking: robot is charging and perimeter will be switched OFF (not working)
sig:  coil signal
mag:  filter result (inside: negative / outside: positive , strengh: distance to perimeter wire)
smag: low-pass filtered without sign (smooth mag)
in:   inside (1) oder outside (0)
on:   perimeter sender active (1) or inactive (0)
  1. Perimeter2 demo
  2. 120m perimeter wire test
