Ardumower PCB
Needed parts
- Main functions
- 1 x Arduino Mega 2560
- 1 x MC33926 motor driver module
- 1 x current sensor module ACS712-5
- Perimeter sender (optional)
- 1 x Arduino Nano
- Coil 220µH, Elko 2,2µF/160V, Resistors (1 Ohm, 1K, 4,7K), Diode 1N4448
- 1 x Arduino Nano
- 1 x LM386 amplifier module
- Capacitor (1 x 4,7nF), 1 x Receiver coils 100mH
- Additional modules
Schematics
PDF for the SVN Version found here :http://www.ardumower.de/index.php/de/forum/dies-und-das/438-schaltplan-svn-version
KiCad Files are in the SVN
PCB assembly
Single sided PCB "eurocard" dimensions 160x100mm So you can build it yourself !!! All used modules are available in the ardumower shop Uses the arduino mega R3 All connections are available on connectors as +5V and GND
You have two options:
- Download Download SVN developer code (recommended) OR
First-time calibration
Wheel motors
ADC calibration
Diagnostic
- loop()-counts per second
- drive home? (1/0)
- "com" - compass course
- "bat" - Battery voltage
- "chg" - Charging current
Starting the mower
Error counter / error beeps
I2C bus / error beeps
Config files
- config.h (old v9.0.3)
- mower.cpp (SVN version)
pfodApp
