Version vom 5. November 2020, 20:25 Uhr von Bernard (Diskussion | Beiträge) (→‎PI Initial boot with Desktop)
Level 2 Raspberry Pi
What you need
Build the SD Card
USB Dongle for mouse.
On first start you can see welcome message and the IP Address for Ethernet
Datei:First start 1.jpg
Change password and remember it (we need it later to connect to PI over wifi) For easy wiki : Pass001
Setup screen
WIFI connecting
Validation and wait again 10 to 30 minutes
