Level 2 Raspberry Pi
What you need
Advanced user
In other case simply follow the full WIKI
Build the SD Card
PI Initial boot with Desktop
USB Dongle for mouse.
REBOOT.
PI SIDE
PC SIDE or Tablet / Phone
NOW WE WORK ON PC OR TABLET
Pi Software part
sudo apt-get update
sudo apt-get upgrade
Python3 Idle
sudo apt-get install idle3
Pygame
Paho Mqtt
sudo pip3 install paho-mqtt
KST Plot
sudo apt-get install kst
Arduino IDE
cd Downloads/arduino-1.8.13
sudo ./install.sh
PiArdu Software
Using VNC Viewer :
cd Documents
sudo chmod -R 755 PiArdumower
cd PiArdumower
mv mower.sh /home/pi/Desktop
Now change
