AzuritBer Pi Explain (English)
Version vom 21. November 2020, 12:20 Uhr von Bernard (Diskussion | Beiträge) (→‎DUE Firmware Update)
Piardu Help
Main Menu
All other icons are explicit.
Auto Page
It's the initial start menu.
Manual page
m --> Start Blade
q --> Stop Blade
Up --> Forward
Down --> Reverse
Right --> Turn right
Left --> Turn left
Space --> Stop all
Setting Page
Main setting
All page are store on tab item :
Simple Setting
DUE Firmware Update
You can upload a new version of AZURITBER in DUE using this button.
Locate this directory and use VNC to transfert file ardumower.ino.bin from your PC to Raspberry PI ,Under folder Piardumower/
Perimeter Setting
Here you can find new button use to start and stop other area sender
ByLane Setting
