AzuritBer Pi Explain (English)
Version vom 22. November 2020, 11:17 Uhr von Bernard (Diskussion | Beiträge) (→‎Perimeter Setting)
Piardu Help
Main Menu
All other icons are explicit.
Auto Page
It's the initial start menu.
Manual page
m --> Start Blade
q --> Stop Blade
Up --> Forward
Down --> Reverse
Right --> Turn right
Left --> Turn left
Space --> Stop all
Setting Page
Main setting
All page are store on tab item :
Simple Setting
DUE Firmware Update
File ardumower.ino.bin is automatically delete from folder to avoid error on next flash : File can't contain "(" or special char
ByLane Setting
Console Page
Test Page
Here you can find new button use to start and stop other area sender
Plot Page
For more info see KST internet page : https://kst-plot.kde.org/
On each page you can select data frequency and click on Start
KST is automatically open and show the graph.
It's better to reduce the KST windows and stop the plot on plot page (Avoid to close KST before stopping data)
When click on stop a message show the name of the .CSV file generate by Piardu , so you can later copy it on your PC and read it using Excel for example.
Timer Page
