AzuritBer Pi Firmware RFID(English)
Version vom 23. November 2020, 19:33 Uhr von Bernard (Diskussion | Beiträge) (→‎Level 3 Raspberry Pi + RFID Reader)
It use SPI interface to communicate with ESP32 and ESP32 replace the bluetooth module HC05 to communicate with PCB1.3, so you can build a small PCB to connect all wire, or order some of them from JLCPCB for example (The same board is also use to build the WIFI sender.)
Using arduino IDE , You need to download the firmware inside ESP32 to have everything working : https://github.com/Boilevin/AzuritBer/tree/master/ESP32_RFID
Here the first version with wrap on smal PCB:
