AzuritBer Pi Firmware RFID(English)
Hardware connecting
Using arduino IDE , You can download firmware inside ESP32 to have everything working : https://github.com/Boilevin/AzuritBer/tree/master/ESP32_RFID
Setting
2 Value need to match to have a mower react (TODO) : TAG Nr AND Mower STATUS
Edit a record
Be careful To edit existing tag : click on the list to choose the tag you want to edit.Click on Delete This Tag to remove old tag from list.Now change value on the text box on right part of the screen , and click on Add this Tag to add the new one.Do not forget to save to file.
What is possible
Mower can DO : 'RTS' or 'FAST_START' or 'SPEED' or 'NEW_AREA'
Fast Return to station
When tag 72B8DB95 is find AND mower Status is BACK_TO_STATION , Mower stop tracking roll 50 Degree and run at new PWM speed of 250 to find again the wire and continue tracking.
Fast Start
When tag 1AD8DB95 is find AND mower Status is TRACK_TO_START , Mower stop tracking roll 28 Degree and run at new PWM speed of 250 to find again the wire and continue tracking.
Here example of new speed it can be use to Dock at low speed or simply change tracking speed when you want :
Here example of area change it can be use to Go to a new mowing area (with other sender)  :
Here example of area change it can be use to back to charging station from other mowing area  :
Result
